[GRASSLIST:2489] Re: g.mremove
Glynn Clements
glynn.clements at virgin.net
Thu Feb 5 21:40:27 EST 2004
Kirk R. Wythers wrote:
> How does one use g.mremove. I have recompiled 5.3 and 5.7 after cvs up
> -dP today, and thought that its use and syntax were similar to
> g.remove. However, I am getting a "command not found" error when I
> attempt to run is from the command line (g.mremove -help yields nothing
> as well). Is g.mremove something separate or require some kind of
> compile option?
No, it's just a script (src/scripts/contrib/g.mremove).
Were there any errors in error.log after compiling?
Glynn Clements <glynn.clements at virgin.net>
