[GRASSLIST:2520] Was: r.in.gdal and libgdal.1.1.dylib
Christof Bigler christof.bigler at colorado.edu
Sun Feb 8 12:58:06 EST 2004
The import works. Apparently, the problem was the missing
libgdal.1.1.dylib in /usr/local/lib. I had a higher libgdal.1.1.9.dylib
version which had been installed with the GRASS binary distribution for
OS X. I installed then the libgdal.1.1.dylib from
http://gdal.velocet.ca/projects/grass.
Another thing: Is it possible to change the man pages for r.in.gdal? It
took me literally hours to find out that the input name should be the
directory and not the file itself. I found this information in a mail
to the list from, I think, 2001, and also in the Open Source GIS book
from Neteler & Mitasova.
Thanks
Christof
On 06.02.2004, at 12:09, Christof Bigler wrote:
> Hi
> I tried to import a raster file (w001001.adf, 358 MB), which is in the
> directory 'codem1nw'. There must be some problems with the
> libgdal.1.1.dylib. Here is some output:
> GRASS 5.0.2 > r.in.gdal in=codem1nw out=codem1nw.r
> dyld: r.in.gdal Undefined symbols:
> r.in.gdal undefined reference to _deflateInit_ expected to be defined
> in /usr/local/lib/libgdal.1.1.dylib
> Trace/BPT trap
> GRASS 5.0.2 > gdalinfo --version
> GDAL 1.1.9.0, released 2003/06/27
> GRASS 5.0.2 > gdalinfo codem1nw
> [I received some reasonable output, no error messages.]
> I work on Mac OS X (10.3.2).
> Thanks for your help
> Christof
