[GRASSLIST:2586] stream layer artifacts
Christopher Fonnesbeck
chris at fonnesbeck.org
Thu Feb 12 22:59:56 EST 2004
I am trying to develop a reasonable stream layer based on the
accumulation output from r.terraflow, but am ending up with odd
artifacts and broken tributaries (see attached graphic). Here are the
steps I have taken:
- Run r.terraflow
- Run r.mapcalc accum_x="if(abs(accum_d8)>x,1,null())", where x=5000
for 10m DEM, x=555 for 30m DEM (trying to extract 50h accumulation
streams)
- Run r.thin to create single-cell width layer
- Run r.to.vector to create vector layer
- Run v.clean to remove spurs
As you can see, however, the result is pretty unsatisfactory. Can
anyone provide some advice on how this stream layer might be improved?
I'm a bit stuck.
Thanks in advance,
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040212/5e473cb6/attachment.bin
