[GRASSLIST:2696] Re: extracting vector attributes
Radim Blazek blazek at itc.it
Fri Feb 20 10:52:50 EST 2004
On Friday 20 February 2004 14:33, Christopher Fonnesbeck wrote:
> Well, my vector layer of polygons comes from a raster layer, via
> r.to.vect, which creates a mysql table with cat and value columns, and
> an empty label column. Then, running:
> v.to.db map=basins type=boundary option=area units=h
> gives me a dbmi protocol error. Is this because the table already
> exists? I am assuming this means I have to write some C code to get the
> areas, create a database column, and load the values.
The column must exist in the table (double precision) and must be specified (col1).
Radim
