I'm trying to import a arc info file with r.in.gdal, because it is not supported by r.in.arc (it has not the header section). The command seems work well but when I display the raster only a little part is right and the rest of the cells of the raster have the value of the category set to 0. Can someone help me? Thank you Leonardo
