[GRASSLIST:2707] Re: Problem importing arc info file
Andrew selkiesdad at twcny.rr.com
Sat Feb 21 06:23:13 EST 2004
You can easily add the appropriate six line header from the file
characteristics
Leonardo Lami wrote:
> I'm trying to import a arc info file with r.in.gdal, because it is not
> supported by r.in.arc (it has not the header section).
> The command seems work well but when I display the raster only a little part
> is right and the rest of the cells of the raster have the value of the
> category set to 0.
> Can someone help me?
> Thank you
> Leonardo
