[GRASSLIST:2700] Re: stitching geotiffs
Richard Greenwood
rich at greenwoodmap.com
Fri Feb 20 12:06:03 EST 2004
Martin du Saire wrote:
>>> Hi,
>>> I am a newbie to GRASS (XT, Cygwin/XFree86; GRASS5.0) and GIS trying
>>> to stitch together a set of NLCD Geo-Tiff (USGS Landsat-5, etc.)
>>> data files for a set of contiguous states in the US. I finally
>>> figured out how to import them using r.in.gdal -o. (If there is some
>>> inherent problem with overriding the projection checking, please let
>>> me know.)
>> If you are importing an image in UTM Zone X into a location defined as
>> UTM Zone X, then you are doing the correct thing by using -o. (You
>> should not use -o to import Zone X into a location of Zone Y). You may
>> also want to use -e, which extends the location if needed.
> So I can import a Zone X map into a Zone Y location? Is this any
> better/worse than using r.proj? The bulk of my area of interest is in a
> single UTM zone (Zone Y), so maybe the distortions generated by
> importing Zone X and Zone Z maps into a location of Zone Y will be small??
No. Sorry I was not clear. You must use r.proj. Import Zone 14 maps into
a Zone 14 location. Zone 15 into a Zone 15 location, etc. And then use
r.proj to bring your Zone 14, and Zone 16 maps into your Zone 15 location.
>>> For starters, how do I go about importing the individual files with
>>> their corresponding UTM zone designations into the same project?
>> Do I understand correctly that you have images in Zone X, Y Z ... and
>> want to have them all in a single projection? If I understand
>> correctly, then you need to use r.proj to reproject from the
>> individual zones into the single target projection. But maybe I do not
>> understand you goal.
> Yes, that is what I am attempting to do. I am stitching together maps
> for MN, IA (Zone 15), WI (Zone 16), and ND, SD (Zone 14). About 80% of
> my area of interest is in Zone 15.
> I also came across a thread from Feb97 that suggested making symbolic
> links of mapsets and then running g.mapsets. What you suggest sound
> more straightforward. Would these procedures be equivalent?
I am not familiar with g.mapsets so I can not comment.
>>> Assuming I can figure that out, do I use r.mask to remove the
>>> background from each of these maps?
>> You probably do not need to mask. I am guessing that the background is
>> NULLs?
> The background is set to "0". Would a NULL be transparent? Maybe use:
> r.null map="name" setnull=0
Yes, that sound correct.
What do you want to get as a final result? A single map (image) or a
whole bunch of maps (image tiles)? If you want a single map, then you
would probably want to use r.patch to assemble all the individual maps
in the Zone 15 location.
Rich
Richard Greenwood
www.greenwoodmap.com
