[GRASSLIST:2701] Re: stitching geotiffs
Martin du Saire
mdusaire at umn.edu
Fri Feb 20 12:46:05 EST 2004
Outstanding! Thank you Richard and Glynn. I think I may eventually have
to r.patch the individual maps. I was playing around with two maps within
a single zone, and the r.stats -a -n map1,map2 output did not reflect what
I expected to be the composite of the two (Actually, the numbers made no
sense at all). One last question:
Without having specific datum in my adjacent zones (14, 16), is there some
way to make upper-bound estimates on the amount of distortion resulting
from the r.proj method=nearest (the maps are land-use/cover)?
Thanks again.
Martin
At 10:06 AM 2/20/2004 -0700, you wrote:
>Martin du Saire wrote:
>>>>Hi,
>>>>I am a newbie to GRASS (XT, Cygwin/XFree86; GRASS5.0) and GIS trying to
>>>>stitch together a set of NLCD Geo-Tiff (USGS Landsat-5, etc.) data
>>>>files for a set of contiguous states in the US. I finally figured out
>>>>how to import them using r.in.gdal -o. (If there is some inherent
>>>>problem with overriding the projection checking, please let me know.)
>>>If you are importing an image in UTM Zone X into a location defined as
>>>UTM Zone X, then you are doing the correct thing by using -o. (You
>>>should not use -o to import Zone X into a location of Zone Y). You may
>>>also want to use -e, which extends the location if needed.
>>So I can import a Zone X map into a Zone Y location? Is this any
>>better/worse than using r.proj? The bulk of my area of interest is in a
>>single UTM zone (Zone Y), so maybe the distortions generated by importing
>>Zone X and Zone Z maps into a location of Zone Y will be small??
>No. Sorry I was not clear. You must use r.proj. Import Zone 14 maps into a
>Zone 14 location. Zone 15 into a Zone 15 location, etc. And then use
>r.proj to bring your Zone 14, and Zone 16 maps into your Zone 15 location.
<snip>
