[GRASSLIST:2719] Re: Grass 5.3-5.7 OS X bin ready. Install from
dmg
Glynn Clements
glynn.clements at virgin.net
Mon Feb 23 20:59:04 EST 2004
Hamish wrote:
> > Binaries OS X are ready.
> > You go to:
> > http://wwwamb.bologna.enea.it/forgrass/
> > and downaload the DMG files.
> > Now you can install Grass with double clic
> > These are the first release.
> LIBRARIES REQUIRED
> Install these programs from FINK:
> - gdbm
> - gd
> gdbm and gd don't do anything and are no longer needed for 5.3 and 5.7.
> (someone correct me if I'm wrong here..)
gdbm was never actually required for anything; the configure tests
have since been removed (although the 5.7 configure.in does still have
the LOC_MSG_USE(DBM support,USE_DBM) line).
GD is no longer required for 5.3 or, AFAICT, 5.7.
Glynn Clements <glynn.clements at virgin.net>
