[GRASSLIST:2729] Re: Grass 5.3-5.7 OS X bin ready. Install from dmg
Lorenzo Moretti lorenzo.moretti at bologna.enea.it
Tue Feb 24 09:17:27 EST 2004
>Hamish wrote:
>>  > Binaries OS X are ready.
>>  > You go to:
>>  > http://wwwamb.bologna.enea.it/forgrass/
>>  > and downaload the DMG files.
>>  > Now you can install Grass with double clic
>>  > These are the first release.
>>  LIBRARIES REQUIRED
>>  Install these programs from FINK:
>>  - gdbm
>>  - gd
>>  gdbm and gd don't do anything and are no longer needed for 5.3 and 5.7.
>>  (someone correct me if I'm wrong here..)
>gdbm was never actually required for anything; the configure tests
>have since been removed (although the 5.7 configure.in does still have
>the LOC_MSG_USE(DBM support,USE_DBM) line).
>GD is no longer required for 5.3 or, AFAICT, 5.7.
>Glynn Clements <glynn.clements at virgin.net>
OK. I have delete them from list.
P.S. Try last GDAL 1.2.0 for OSX im my site. HDF support now work
using gdalwarp utility for converting HDF format to Geotiff coordinate
________________________________________________________________________
||       Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|   ENEA prot              Web: http://wwwamb.bologna.enea.it/
||   |   via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (res.)
~~~~~~   40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
			Download GRASS for MAC OS X:
