[GRASSLIST:2727] Re: v.digit in grass 5.7 editing attributes problem
FRANCESCO
francesco.pirotti at unipd.it
Tue Feb 24 16:15:31 EST 2004
Is F_generate a function of which library? Maybe the library I have is damaged
and defaults to F_VIEW??
On Tuesday 24 February 2004 11:38, you wrote:
> On Tuesday 24 February 2004 18:34, FRANCESCO wrote:
> > Hello GRASSies,
> > I have a recurring problem in GRASS 5.7:
> > for some reason if I digitize new vectors or try to edit old ones I
> > cannot edit any of the attribute values in the columns in my database
> > (simple dbf connection).
> > When I query a vector I get only the window with the values, without a
> > submit button to update the value. ( In case I digitize a new vector I
> > get default value of "0" for int columns added after the 'cat' column and
> > no "submit" button).
> > I can say already that the vector is in my mapset, that the permissions
> > are set right.
> > Does anybody know what the causes could be?
> No idea, as I have already written, the form is either type F_VIEW or
> F_EDIT and in v.digit is used
> F_generate ( Fi->driver, Fi->database, Fi->table, Fi->key, cat, NULL, NULL,
> F_EDIT, F_HTML, &form);
> Radim
