[GRASSLIST:2740] Re: v.digit in grass 5.7 editing attributes problem
Radim Blazek blazek at itc.it
Wed Feb 25 05:02:38 EST 2004
On Tuesday 24 February 2004 22:15, FRANCESCO wrote:
> Is F_generate a function of which library? Maybe the library I have is
> damaged and defaults to F_VIEW??
Form library grass51/lib/form
Radim
> On Tuesday 24 February 2004 11:38, you wrote:
> > On Tuesday 24 February 2004 18:34, FRANCESCO wrote:
> > > Hello GRASSies,
> > > I have a recurring problem in GRASS 5.7:
> > > for some reason if I digitize new vectors or try to edit old ones I
> > > cannot edit any of the attribute values in the columns in my database
> > > (simple dbf connection).
> > > When I query a vector  I get only the window with the values, without a
> > > submit button to update the value.  ( In case I digitize a new vector I
> > > get default value of "0" for int columns added after the 'cat' column
> > > and no "submit" button).
> > > I can say already that the vector is in my mapset, that the permissions
> > > are set right.
> > > Does anybody know what the causes could be?
> > No idea, as I have already written, the form is either type F_VIEW or
> > F_EDIT and in v.digit is used
> > F_generate ( Fi->driver, Fi->database, Fi->table, Fi->key, cat, NULL,
> > NULL, F_EDIT, F_HTML, &form);
> > Radim
