[GRASSLIST:2735] Re: r.buffer
Glynn Clements
glynn.clements at virgin.net
Tue Feb 24 16:52:22 EST 2004
Martin du Saire wrote:
> I need to delineate a zone to encompass a 500km radius around a site. The
> final goal is to r.patch multiple maps into this zone. When I use r.buffer
> it generates a G_malloc error: out of memory. My /tmp directory is
> virtually empty. I have lots of disk space. I am running Grass5.0 in
> Cygwin\Xfree86 in WindowsXT.
> Any suggestions, including a way to achieve the patch without r.buffer if
> possible?
If the boundary doesn't need to be entirely accurate, reducing the
region resolution with "g.region res=..." will probably reduce the
memory requirements.
Glynn Clements <glynn.clements at virgin.net>
