[GRASSLIST:2742] g.select.pg
    Sabine Grabner
    csab7771 at uibk.ac.at
    Wed Feb 25 05:33:26 EST 2004
hello,
i tried to run command
  g.select.pg host=138.232.34.82 database=rsdb
i got following error-message:
  Error: select Postgres:FATAL:  no pg_hba.conf entry for host
"::ffff:138.232.34.94", user "sabine", database "template1"
what does the required database (rsdb) have to do with database template1?
the following command is working:
  psql -d rsdb -h 138.232.34.82 -U sabine
can anyone give me some advice how to continue accessing the database?
thank you, sabine
