[GRASSLIST:2744] Re: Problem importing arc info file
    Leonardo Lami
    leo.lami at katamail.com
    Wed Feb 25 10:51:15 EST 2004
I added the header at the beginning of w001001.adf file in this way:
ncols 2492
nrows 2272
xllcorner 4675800
yllcorner 1550000
cellsize 100
NODATA_value -9999
ÿÿü Xîè  "#Ð#.»7A&'
 èŠRAì ˆÈî 8A±Ù ŸÁœRA2  3  4  5  6 (7 08 89 @: H; P< X= `> h? p@ xA €B ˆC D
~E  F šG °H žI ÀJ ÈK ÐL ØM àN èO ðP øQ  R   S   T   U   V  (W  0X  8Y  @Z  H[
P\  X]  `^  h_  p`  xa  €b  ˆc  d  ~e   f  šg  °h  ži  Àj  Èk  Ðl  Øm  àn
èo  ðp  øq  r   s   t   u   v  (w  0x  8y  @z  H{  P|  X}  `~  h  p€  x  €,
ˆƒ  "  ~…   †  š‡  °ˆ  ž‰  ÀŠ  È<  ÐŒ  Ø  àŽ  è  ð  ø'  '   "   "   *   -
(-  0~  8™  @š  H>  Pœ  X  `ž  hŸ  p   x¡  €¢  ˆ£  €  ~¥   Š  š§  °š  ž©
Àª  È«  Ь  Ø  à®  è¯  ð°  ø±  ²   ³   Ž   µ   ¶  (·  0ž  8¹  @º  H»  PŒ  Xœ
`Ÿ  h¿  pÀ  xÁ  €Â  ˆÃ  Ä  ~Å   Æ  šÇ  °È  žÉ  ÀÊ  ÈË  ÐÌ.......
I add part of the file because I'm not sure if it is data file.
But the output message now say:
r.in.arc input=/home/Documenti/AAA-verificare/DTM_nuovo/dtm/w001001x.adf
output=w001001 type=CELL mult=1.0  0%ERROR: data conversion failed at row 1,
col 1
Where do I wrong?
Thank you again
Leonardo Lami
Alle 14:31, martedì 24 febbraio 2004, hai scritto:
> The header must be positioned at the beginning of the data file, the
> entries for each point must be listed one per line and ALL headers must
> be present AND must have correct values.
> e.g.
> ncols 301
> nrows 301
> xllcorner -75.4421
> yllcorner 44.2576
> cellsize 0.0001
> NODATA_value -9999
> val1
> val2
> val90601
> EOF
> For UTM or other coordinates in meters the values would be in
> appropriate units, not degress as in this example.
> Leonardo Lami wrote:
> >Sorry but I have never worked with arc/info files and so i have again
> >problems.
> >I have seven files for my dtm layer:
> >dblbnd.adf
> >hdr.adf
> >log
> >prj.adf
> >sta.adf
> >w001001.adf
> >w001001x.adf
> >I added:
> >yllcorner:4675800
> >xllcorner:1550000
> >nrows:2492
> >ncols:2272
> >cellsize:100
> >at the bottom of the w001001.adf file but when i run r.in.arc the output
> >message say:
> >r.in.arc: ** errors detected in header section **
> >  illegal line in header
> >  "yllcorner:4675800"
> >  "yllcorner" field missing from header
> >  "xllcorner" field missing from header
> >  "nrows" field missing from header
> >  "ncols" field missing from header
> >  "cellsize" field missing from header
> >  "nodata_value" field missing from header
> >Can't proceed
> >May be I mismatch the file where I add the header or its format.
> >Can you help me
> >Thank you very much
> >Leonardo Lami
