[GRASSLIST:2745] Re: Problem importing arc info file
"Fernández-Victorio Arévalo, Gon
Wed Feb 25 11:12:13 EST 2004
Leonardo Lami wrote:
> I added the header at the beginning of w001001.adf file in this way:
Hi Leonardo:
You seem to be be importing and ARC/INFO binary grid with r.in.arc
which is a tool to import ARC/INFO ASCII grids, so AFAICT it won't work.
It seems that ARC/INFO binary grid is supported with GDAL [1], so
maybe you should consider using r.in.gdal.
HTH
Gonzalo
[1] http://www.remotesensing.org/gdal/frmt_various.html#AIG
