[GRASSLIST:2752] Re: cannot compile grass57 on mandrake 9.2
Markus Neteler
neteler at itc.it
Wed Feb 25 18:40:06 EST 2004
On Tue, Feb 24, 2004 at 12:36:40PM +0100, daniel.pastor at uam.es wrote:
> Hello,
> I am trying to compile grass57 on mandrake 9.2, and it seems work, but when I
> tried to run the program (text mode) this error happens:
> /usr/local/grass57/etc/Init.sh: line 1: g.gisenv: command not found
> GRASS 5.7.-cvs:/opt > g.list rast
> bash: g.list: command not found
Are you sure that the compilation went well? I use it on Mandrake 9.1,
which should not be so different from 9.2.
Markus
> and no command works.
> if I un the programm as text: grass -text the problem is greater, and I cannot
> begin grass:
> /usr/local/grass57/etc/Init.sh: line 497: GISDBASE: parameter null or not set
> [daniel at grass opt]$
> But, I have succesfully compiled grass50 first and all commands work, in a text
> and in a graphical mode.
> Any ideas?
> regards and thanks a lot.
> Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
> ------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
