[GRASSLIST:2753] Re: v.in.dwg
Markus Neteler
neteler at itc.it
Wed Feb 25 18:43:55 EST 2004
On Tue, Feb 24, 2004 at 03:24:29PM +0100, Michele wrote:
> Hi,
> starting to try the new vector management in grass57, I'm looking for the
> module called v.in.dwg
> in grass57 tutorial, maibe this function is performed with a new one with a
> different name?
> thanks, Michele.
v.in.dwg needs the openDWG libs: you have to compile this command
locally after getting these libs. We are not allowed to distribute
v.in.dwg binaries due to the openDWG license.
I'll add a hint in the tutorial.
Markus
