[GRASSLIST:2768] Re: : NVIZ
samuel cavalcante
grassmanbr at hotmail.com
Thu Feb 26 22:54:00 EST 2004
hi hamish,
the error message is the following:
child killed: segmentation violation
while executing
"exec /grass/etc/nviz2.2/NVWISH2.2 -f
/grass/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/grass/bin/nviz" line 16)
actually i have installed grass through a debian package, but unstalled it
and re installed grass through grass.itc.it binaries..but it is still not
runing...
thanks in advance
samuel
>From: Hamish <hamish_nospam at yahoo.com>
>To: "samuel cavalcante" <grassmanbr at hotmail.com>
>Subject: Re: [GRASSLIST:2759] : NVIZ
>Date: Fri, 27 Feb 2004 10:44:01 +1300
> > i am having problems with running nviz..i've read here in the list
> > that there is a problem with tcl8.4 version (used by grass) because
> > nviz runs better in a tcl8.3 environment...i have tcl8.3 installed in
> > my pc..how do i proceed in this case? does someone can help me giving
> > step by step instructions?
>You'll have to provide a clearer description of the problem. Sending a
>cut & paste of the command line and error message to the grasslist is
>best.
> > i am using a debian/knoppix based distro...the ultimate version (but
> > not with the newest linux kernell)
>I'm using Debian here, NVIZ works fine.
>Make sure that you are compiling GRASS with the tcl8.3-dev and tk8.3-dev
>packages, not just that tcltk 8.3 is installed on the system. The binary
>Debian grass package is known to be compiled with 8.4 & thus nviz
>doesn't work there.
>good luck,
>Hamish
_________________________________________________________________
MSN Hotmail, o maior webmail do Brasil. http://www.hotmail.com
