[GRASSLIST:2169] Re: r.in.gdal : Unresolvable problems?
Ben Logan
ben at wblogan.net
Fri Jan 9 08:25:38 EST 2004
On Fri, Jan 09, 2004 at 09:29:45AM +0100, Markus Neteler wrote:
> Ben,
> I have downloaded o36080g5.zip map and imported without
> problems using
> - GRASS 5.3-CVS
> - GDAL-CVS
> - compiled GRASS with --with-gdal
> My suggestion is to polish the system and eliminate all
> GDAL libs. Probably there are different versions in
> different directories? Check out for
> - gdal.a
> - libgdal*
> - ogr*
> etc
Hi, Markus. Thanks for responding.
This morning I ran 'find' from the root of my filesystem and searched
for anything named gdal* libgdal* or ogr*. I removed everything (gdal
related) that turned up, removed the grass installation and sources
and removed the gdal sources. I then compiled gdal-1.1.9, and grass
5.0.3 using --with-gdal (and also --without-fftw, but I'm assuming
that shouldn't affect it). I had the same problem as before.
As soon as I can get to a fast connection, I'll grab the CVS versions
of grass and gdal and try again. If that doesn't work, I'll really be
lost. I was hoping to get it working soon because I'm trying to
create a Knoppix-based GRASS demo cd using data from my area. I want
to make several copies and distribute them at my community college
because I think it would be a great way to let people play with grass
and see what it can do without having to know how to set it
up...especially since most people don't run *nix.
I'll let you know if the CVS version works or not. Any ideas if it
doesn't?
Thanks,
Ben
Ben Logan
Google Answers Researcher
answers.google.com
When you're searching for information, Google Answers.
OpenPGP Key ID: A1ADD1F0
Fingerprint: E32C 1CF9 C2FE DFC9 BB5C A24F 57DB 5679 A1AD D1F0
Get it from http://cyclist.wblogan.net/benlogan.gpg
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040109/1a3fec27/attachment.bin
