[GRASSLIST:2174] Re: r.in.gdal : Unresolvable problems?
Glynn Clements glynn.clements at virgin.net
Fri Jan 9 12:45:31 EST 2004
Ben Logan wrote:
> This morning I ran 'find' from the root of my filesystem and searched
> for anything named gdal* libgdal* or ogr*.  I removed everything (gdal
> related) that turned up, removed the grass installation and sources
> and removed the gdal sources.  I then compiled gdal-1.1.9, and grass
> 5.0.3 using --with-gdal (and also --without-fftw, but I'm assuming
> that shouldn't affect it).  I had the same problem as before.
One comment: when building GDAL for use with GRASS, it may help to use
the --without-grass configure switch.
Glynn Clements <glynn.clements at virgin.net>
