[GRASSLIST:2188] Re: r.in.gdal compile failure
David Orme d.orme at imperial.ac.uk
Mon Jan 12 10:43:19 EST 2004
Hi everyone,
To answer my own post: I had r.in.gdal failing to compile because it
failed to find libtiff and libpng. It turned out that I hadn't
installed libpng properly (thanks to William K for notes on that and
building libjpeg.dylib).
For libtiff, I had to edit [tiffsrc]/libtiff/Makefile.in - the shared
library building command has the install_name hardcoded without a path
(lines 216-218):
> DARWINdso: ${OBJS}
>         ${CC} -dynamiclib -undefined error \
>           -install_name libtiff. at DSOSUF@ \
I changed this to:
> DARWINdso: ${OBJS}
>           -install_name /usr/local/lib/libtiff. at DSOSUF@ \
and then recompiled gdal. Now the otool listing shows paths for all the
shared libraries:
> bash-2.05a$ otool -L /usr/local/lib/libgdal.dylib
> /usr/local/lib/libgdal.dylib:
>         /usr/local/lib/libgdal.1.dylib (compatibility version 3.0.0,
> current version 3.9.0)
>         /usr/local/lib/libiconv.2.dylib (compatibility version 5.0.0,
> current version 5.0.0)
>         /usr/local/lib/libdl.1.dylib (compatibility version 1.0.0,
> current version 1.0.0)
>         /usr/local/lib/libodbc.1.dylib (compatibility version 2.0.0,
> current version 2.0.0)
>         /usr/local/lib/libjpeg.62.dylib (compatibility version 63.0.0,
> current version 63.0.0)
>         /usr/local/lib/libtiff.dylib (compatibility version 0.0.0,
> current version 0.0.0)
>         /usr/local/lib/libpng.3.dylib (compatibility version 3.0.0,
> current version 3.0.0)
>         /usr/lib/libz.1.1.3.dylib (compatibility version 1.0.0,
> current version 1.1.3)
>         /usr/lib/libSystem.B.dylib (compatibility version 1.0.0,
If this is total gibberish or likely to cause problems down the line,
can someone please tell me!
Cheers,
David
On Friday, January 9, 2004, at 07:49  pm, William K wrote:
>> As a side issue, the gdal compile requires libjpeg.dylib and I can't
>> get jpeg-6b to produce dynamic libraries. I can get round this by
>> using --with-jpeg=internal in the gdal configure but does anyone know
>> how to build libjpeg.dylib?
>> Any suggestions?
> There is a patch you can make to get libjpeg dynamic libraries.  I
> don't have the details in my head, but look at my GRASS building
> intructions page for Mac OS X.  The instructions are for GRASS 5.3,
> but the library build info works for 5.7.
> <http://webpages.charter.net/kyngchaos/macosx/grassinstall.html>
> William Kyngesburye <kyngchaos at charter.net>
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
