[GRASSLIST:2211] Re: Import into rast from tiff
Ben Logan ben at wblogan.net
Wed Jan 14 06:56:05 EST 2004
On Wed, Jan 14, 2004 at 01:00:13PM +0300, ????????? ??????? wrote:
> Hi, all
> Can I import tiff image into 1 rast instead of 3 r,g,b rasts?
> Why all of 3 imported images looks like gray and broken (with vertical
> lines)?
> I used the command r.in.tiff input=data.tiff output=mydata because
> r.in.gdal is not working on Cygwin due to stackdump.
I'm not positive about r.in.tiff, but I assume it works the same way
as r.in.gdal when importing tiffs.  If so, you need to run i.composite
after running r.in.tiff.  You should have an image group matching the
name you imported the tiff under.  Use that and set the RGB
components, and it should give you the color image you were expecting
to see.
HTH,
Ben
Ben Logan
Google Answers Researcher
answers.google.com
When you're searching for information, Google Answers.
OpenPGP Key ID: A1ADD1F0
Fingerprint: E32C 1CF9 C2FE DFC9 BB5C  A24F 57DB 5679 A1AD D1F0
Get it from http://cyclist.wblogan.net/benlogan.gpg
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040114/3c414edb/attachment.bin
