[GRASSLIST:2241] Re: i.points
Markus Neteler
neteler at itc.it
Thu Jan 15 03:45:21 EST 2004
On Wed, Jan 14, 2004 at 09:20:59AM -0600, Kirk R. Wythers wrote:
> How does one delete points in order to just start over? I have already
> toggled the points off in the analyze section, but they still appear in
> red on the map. Is there a way to simply b"blow away" the all points
> and start anew?
The only (simple) method is to edit the POINTS file:
edit <gisdbase>/<location>/<mapset>/group/<groupname>/POINTS
It's an ASCII file, the last column indicates if the point
is active (1) or disabled (0).
Markus
