[GRASSLIST:2323] Re: GIS ERROR: error while writing to temp file: No such file or directory
Edmund Blackadder
edmund at helmug.gr
Thu Jan 22 06:28:47 EST 2004
HI and thanks for the help,
On 22 Jan 2004, at 05:47, Glynn Clements wrote:
> Some questions:
> 1. Does the temporary files directory (.../.tmp/<hostname>) exist?
There is a .tmp dir that gets created in the right place when i run
i.rectify under . And there is a hostname dir inside it
> 2. Do you have write permission for that directory?
NO.. I do not have w permission for .tmp/<hostname>
> 3. Are there any files in that directory for which you don't have
> write permission?
> 4. Do you have write permission for the mapset directory?
I do
I changed the permissions recursively in the dir .tmp/<hostname>
But the problem still exists. Then i checked the permissions of the
pid-named file inside <hostname> while i.rectify was working. The
pid-named file does not have write permissions
How can i fix that??This file disappears after rectification stops.
Konstantinos Theofilis
