[GRASSLIST:2369] Fun  with gdal - Follow-up
    SWlab
    swlab at cornell.edu
    Tue Jan 27 20:51:49 EST 2004
Hello,
I eventually installed the 2004/01/23 CVS version of grass 5.3 to solve the
(in)famous segfault pb in gdal (cf message 2333). Thanks for the tip, it
solved my problem, I'm now able to import my dem maps. And now, for a GIS
question:
I need to get the topography of an area at the intersection of 4 USGS 7.5
quadrangles. My four individual DEMs are in UTM18, NAD27. I defined a region
large enough to cover the four quadrangles at once, UTM18 NAD27 also. What's
the best option ?
1. To import each DEM in my current region through gdal, and use r.patch ?
2. To create a new location for each DEM with gdal, then import each DEM from
its new location to my current region (and then running r.patch...) ?
I tried the two options, and computed a difference: there's a difference
indeed,from +10 to -15 on the picture I join. Which method should I follow ?
And thread hijacking:
When I patch the 4 DEMs in a new one, some cells are missing (undefined). Is
there a simple algorithm to fill for the missing data ?
Thanks a lot for any comment/idea
P.
Soil & Water Laboratory
Dept. of Biological & Environmental Engineering
Cornell University
ITHACA, NY 14853
Tel: (607)255.2463
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040127/8fd9dd34/tmp.png
