[GRASSLIST:2396] Re: s.surf.rst generating seemingly empty rasters
Glynn Clements glynn.clements at virgin.net
Thu Jan 29 12:43:35 EST 2004
Matthew Tennant wrote:
> > Are you sure that setting is effective? What is the result of running
> > the command "echo $CYGWIN" within the GRASS shell?
> > Also, what does "mount" say? For a mounted filesystem, the mount
> > options override the CYGWIN setting.
> echo $CYGWIN results in a blank line being outputted
> mount results in the output below (I have a lot of substed drives on my
> Win2000 set-up)
> Looks like I'm still in textmode! Any suggestions as to how to set
> binmode? My sites file is located
> in c:\cygwin\data\....... My grass installation is in
> c:\cygwin\usr\local\., I think.
> c:\system\usr\X11R6\lib\X11\fonts on /usr/X11R6/lib/X11/fonts type system
> (binmode)
> c:\cygwin\bin on /usr/bin/ type system (textmode)
> c:\cygwin\lib on /usr/lib/ type system (textmode)
> c:\cygwin on / type system (textmode)
This is the problem. Try:
	mount -b c:\cygwin /
Glynn Clements <glynn.clements at virgin.net>
