[GRASSLIST:2400] Re: scan-resolution for maps
Geotronix
mail-list at geotux.it
Thu Jan 29 11:57:21 EST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
* mercoledì 28 gennaio 2004, alle 16:59, E. Koster scrive:
> Dear grass-list,
> I remember from several years ago (grass4.x) there was a document from Cerl
> talking about resolution and accuracy of maps. This article took the
> minimal line-width on a map, and calculated, based on the map-scale which
> resolution was best to scan the map.
> In my files I cannot find the document I mentioned, and since I do not know
> the title a search on the web is nearly impossible.
> Probably some of you will know what text I am refering to. Could you please
> send me a reference, or introduce me to any other literature on this
> subject?
> the map I want to scan was created in 1639 using a copper-plate. The
> instrument used to engrave can make lines up to a 0.1 mm in width. The
> resolution of the map is 1:2.400. At what resolution I should scan not to
> have an overkill of information?
I think the document you are looking for is "GRASS Tutorial: Image
processing" by Victoria Harmon and Michael Shapiro. It there that I
learnt something on the scanning resolutions.
Bye
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
iD8DBQFAGTtxIRaQQEznKxURAhqcAKDLrcrwpjDWnI9A6C1Q4SBEUpXbZwCdGM40
TGDipQ0ZKmy+XpyWw3Oy+s8=
=vmy5
-----END PGP SIGNATURE-----
