[GRASSLIST:2416] Re: v.proj problems
morten at untamo.net morten at untamo.net
Fri Jan 30 17:39:31 EST 2004
The values for north and south in the utm location should both be
positive. I tried
north:      8112600
south:      3770400
and got Chile nicely in the monitor window.
rgds
Morten
On Fri, 30 Jan 2004, Ian Macmillan wrote:
> Sorry about that, here they are.
> -ian
> projection: 1 (UTM)
> zone:       19
> datum:      wgs84
> ellipsoid:  wgs84
> north:      -3236376
> south:      -4428820
> west:       -363600
> east:       974700
> nsres:      902
> ewres:      900
> rows:       1322
> cols:       1487
> PROJ_INFO file:
> datum:   wgs84
> proj:    utm
> ellps:   wgs84
> a:       6378137.0000000000
> es:      0.0066943800
> f:       298.2572235630
> zone:    19
> south:   defined
> PROJ_UNITS file:
> unit:    meter
> units:   meters
> meters:  1.0
> projection: 3 (Latitude-Longitude)
> zone:       0
> datum:      wgs84
> ellipsoid:  wgs84
> north:      30:29:46.068S
> south:      41:00:00.936S
> west:       73:40:13.872W
> east:       67:49:52.284W
> nsres:      0:00:30.0118
> ewres:      0:00:29.988
> rows:       1260
> cols:       701
> PROJ_INFO file:
> datum:   wgs84
> proj:    ll
> ellps:   wgs84
> PROJ_UNITS file:
> unit:    degree
> units:   degrees
> meters:  1.0
