[GRASSLIST:2418] Re: v.proj problems
morten at untamo.net
Fri Jan 30 18:34:03 EST 2004
On Fri, 30 Jan 2004, Ian Macmillan wrote:
> Quoting morten at untamo.net:
> > The values for north and south in the utm location should both be
> > positive. I tried
> > north: 8112600
> > south: 3770400
> > and got Chile nicely in the monitor window.
> > rgds
> > Morten
> Hmm, that is interesting, then I guess the problem isn't with v.proj. It is
> with r.in.gdal. I imported a bunch of landsat rasters (from university of
> maryland). The utm region that I gave is the region that shows when I set
> g.region raster=mylandsat. I have posted the meta file here for the geotiffs i
> imported.
Don't know about that, but in proj (and grass) the utm projection for
the south hemisphere has a built-in false northing of -10,000,000 meters.
So north and south in your location are measured as the distance from the
south pole instead of from the equator.
Morten
> www.uweb.ucsb.edu/~ian_macmillan/p233r084_7x19991226.txt
> The coordinates given are all in latlong, however the projection said utm, hence
> my importing them into a utm location. did I do something wrong there?
> -ian
