[GRASSLIST:3799] Re: another scripting question
Glynn Clements
glynn.clements at virgin.net
Thu Jul 1 18:40:57 EDT 2004
Kirk R. Wythers wrote:
> I'm looking for a little more scripting advice as I put together a
> couple of tools to handle an image rectifying job. I think I have most
> of what I need, but I'm stuck on what I perceive as one of the first
> steps.
> Both scripts need to run through all files in a particular mapset.
> Therefor my first question is how to step through each map within the
> current mapset, so that the same procedure can be applied to every one
> of them? Most of the examples I've found use the map name as an
> argument specified on the command line.
> Any tips?
1. List the "cell" directory.
eval `g.gisenv`
ls "$GISDBASE/$LOCATION_NAME/$MAPSET/cell" | while read map ; do
... $map
done
2. Parse the output of "g.list rast".
Option 1 is likely to be the easiest; the output of g.list isn't
exactly easy to parse.
Glynn Clements <glynn.clements at virgin.net>
