[GRASSLIST:3804] nviz startup problem
Michael Holzmann
mholzmann at iaks.de
Mon Jul 5 04:04:33 EDT 2004
hello,
I am a beginner in Linux and Grass57. After the Installation on Suse Linux
9.1 at start the following message appears.
This version running thru the Bash Shell (/bin/bash)
Help is available with the command: g.manual
See the licence terms with: g.version -c
If required, restart the graphical user interface with: d.m &
Start the graphical menu system with: tcltkgrass &
When ready to quit enter: exit
bash: /etc/profile: line 290: syntax error: unexpected end of file
GRASS 5.7.cvs:~ >
The Program start and i can work with Grass57, only when i will start nviz
following error message appears.
can not find channel named "couldn't execute "nviz2.2_script": no such file
or directory"
or directory"
while executing
"fconfigure $msg -blocking 0"
invoked from within
".run invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 22)
invoked from within
"tk::ButtonUp .run"
(command bound to event)
Is the error at nviz caused by the profile file?
What means "unexpected end of file"? Is an environment variable for nviz
required or a link to make.
How can i solve the Problems?
Thanks!
