[GRASSLIST:3805] v.to.rast
Sabine Grabner
csab7771 at uibk.ac.at
Mon Jul 5 04:35:04 EDT 2004
hello, i need a picture of my digital elevation model with a few
meteorological stations for a power point presentation. i thought i convert my
vector data to raster and merge the two rasters together.
but when i use v.to.rast i get only one station out of 30!?
the table of the vector looks like this:
cat | x | y | z | name
1 | 194197.23537 | 5191251.584895 | 1906 | Vent
2 | 226928.392144 | 5236860.658687 | 579 | Innsbruck-Flughafen
3 | 202576.650269 | 5192186.387956 | 1938 | Obergurgl
4 | 265000.467163 | 5225174.19567 | 643 | Mayrhofen
GRASS 5.7.0:~/diss/grassdata > v.to.rast in=meteostation out=meteostation
use=...
no matter which use option i take,i get only one point, which appears always
at the same coordinates also independent of the cat i choose.
using use=attr i get an error message:
use=attr col=name
Loading vector information ...ERROR: Column type not supported by
db_select_to_array()
using 'z' instead of 'name' works, but i get also just one point.
by the way, my point is very small, is there a possibility to make it larger?
does anyone have an idea how to get my items to the power point presentation?
thank you, sabine
