[GRASSLIST:3817] Startup problems - OSX 10.3.3
Steve Dorsey
steve at dorseygraphics.com
Tue Jul 6 16:18:06 EDT 2004
Hello
I am trying to start up Grass on a Mac G5 10.3.4 machine with X11. The GUI window pops
up on launch, but it opens a "grass57" terminal window with the info below. It seems that
things are not loading properly. Can anyone offer a suggestion?
Thanks,
------S
Application initialization failed: Can't find a usable init.tcl in the following
directories:
@TCL_IN_FRAMEWORK@ /usr/lib/tcl8.4 /lib/tcl8.4 /usr/library /library /tcl8.4
.4/library @TCL_IN_FRAMEWORK@
Welcome to GRASS 5.7.-cvs (2004)
Geographic Resources Analysis Support System (GRASS) is Copyright,
1999-2004 by the GRASS Development Team, and licensed under terms of the
GNU General Public License (GPL) version 2.
This GRASS 5.7.-cvs release is coordinated and produced by the
GRASS Development Team headquartered at ITC-irst (Trento, Italy) with
contributions from all over the world.
This program is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
General Public License for more details.
This version running thru the Bash Shell (/bin/bash)
Help is available with the command: g.manual
See the licence terms with: g.version -c
If required, restart the graphical user interface with: d.m &
When ready to quit enter: exit
directories:
This probably means that Tcl wasn't installed properly.
directories:
Error in startup script: can't find package BWidget 1.2.1
while executing
"package require -exact BWidget 1.2.1"
(file "/Applications/Grass/grass57/etc/dm/d.m.tcl" line 2)
Error in startup script: invalid command name "bind"
while executing
"bind balloon <Enter> {
set balloonHelp(%W,after) [after 400 {updateBalloonHelp %W}]
(procedure "BalloonInit" line 2)
invoked from within
"BalloonInit"
(file "/Applications/Grass/grass57/tcltkgrass/main/gui.tcl" line 1677)
invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
invoked from within
"if [catch {source $env(TCLTKGRASSBASE)/main/gui.tcl}] {
set env(TCLTKGRASSBASE) $env(GISBASE)/tcltkgrass
source $env(TCLTKGRASSBASE)/main/gui...."
(file "/Applications/Grass/grass57/bin/tcltkgrass" line 26)
GRASS 5.7.-cvs:~ >
