[GRASSLIST:3875] Re: GRASS 5.7 - now it compiles but can't run display manager
Markus Neteler neteler at itc.it
Mon Jul 12 04:46:09 EDT 2004
On Sun, Jul 11, 2004 at 04:33:20PM -0300, Carlos Henrique Grohmann wrote:
> Dear friends of this list
> I am trying to make GRASS 5.7 run on Slackware 10.0. until yesterday, I couldn't
> compile it, so I download the CVS-HEAD for 5.3 and 5.7, used the configuration
> script and it compiled OK. the problem now is that d.m won't run. here is the
> error msg:
> GRASS 5.7.cvs:~ > d.m &
> [1] 25635
> GRASS 5.7.cvs:~ > Error in startup script: ps.map: error while loading shared
> libraries: libdfftw.so.2: cannot open shared object file: No such file or
> directory
>     while executing
> "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> "DmPrint::init"
>     (procedure "main" line 27)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass5.7.cvs-i686-pc-linux-gnu-10_07_2004/etc/dm/d.m.tcl"
> line 773)
> So, why it have to call ps.map? and why ps.map needs fftw?
I think ps.map depends on fftw because it uses libgis which depends on libgmath
which can be compiled with fftw support.
> I have ftw versions 2.15 and 3.0.1 installed, but no libdfftw.so.2.
Note: You can only use FFTW 2.x with GRASS.
Markus
