[GRASSLIST:3877] fftw.so.2 error fixed
Carlos Henrique Grohmann
guano at usp.br
Mon Jul 12 15:14:46 EDT 2004
So, for those with the ps.map problem with d.m in grass 5.7, it is possible to
fix by installing fftw2.15, which will provide libfftw.so.2, and will be
necessary to make a link to it named lidfftw.so.2, in /usr/lib.
the package can be found in rpm format (I guess that mandrake uses it) and in
tgz (for slack users).
if anyone needs the tgz package, I can send it.
cheers
Carlos
Carlos Henrique Grohmann - Guano
Geologist M.Sc - PhD Student at IGc-USP - Brazil
Linux User #89721 - guano at usp dot br -
Citando Glynn Clements <glynn.clements at virgin.net>:
> Carlos Henrique Grohmann wrote:
> > I am trying to make GRASS 5.7 run on Slackware 10.0. until
> > yesterday, I couldn't compile it, so I download the CVS-HEAD for 5.3
> > and 5.7, used the configuration script and it compiled OK. the
> > problem now is that d.m won't run. here is the error msg:
> > GRASS 5.7.cvs:~ > d.m &
> > [1] 25635
> > GRASS 5.7.cvs:~ > Error in startup script: ps.map: error while loading
> shared
> > libraries: libdfftw.so.2: cannot open shared object file: No such file or
> > directory
> > while executing
> > "exec ps.map -p"
> > So, why it have to call ps.map?
> It runs "ps.map -p", which outputs a list of the paper sizes which
> ps.map understands. This list is used to initialise the "Paper format"
> combo box in the print dialog.
> > and why ps.map needs fftw?
> It is linked against the gmath library, which in turn requires FFTW.
> However, I can't see an obvious reason for the gmath dependency.
> > I have ftw versions 2.15 and 3.0.1 installed, but no libdfftw.so.2.
> One possibility is that libfftw was compiled as libdfftw.so.2 then
> renamed to something else (e.g. libfftw.so.2). That won't work. Shared
> libraries have their "soname" (shared object name) compiled into them,
> and that name is stored in any executables which are linked against
> it, and that is the name which the loader will look for when loading
> the executables.
> > if I made a link to other file will it work?
> Yes.
> > (like I have to do with
> > tcl and tk 8.3 to get NVIZ working). I yes, from what file
> Whichever file the linker used when it linked libgrass_gmath.so. Look
> for the definition of FFTWLIB in include/Make/Platform.make. That will
> contain either "-lfftw" or "-ldfftw", possibly in addition to a -L
> switch. For the former, you need to locate a symlink or file named
> libfftw.so, typically in /usr/lib or /usr/local/lib; for the latter,
> you need to locate libdfftw.so.
> > and where should the link be?
> Anywhere that the loader will find it, i.e. in /usr/lib or in any of
> the directories listed in /etc/ld.so.conf. Also, you need to run
> ldconfig once the link has been added.
