[GRASSLIST:3892] Re: concurrent use
Glynn Clements
glynn.clements at virgin.net
Tue Jul 13 19:41:35 EDT 2004
tatel at euskalnet.net wrote:
> After recompiling from CVS, this is what I get when starting 57:
> /usr/local/grass-5.7.cvs/etc/Init.sh: g.gisenv: command not found
> I guess this is somewhat dumb, but I can't find it.
> What should I do?
Do the following files exist:
/usr/local/grass-5.7.cvs/bin/g.gisenv
/usr/local/grass-5.7.cvs/etc/bin/cmd/g.gisenv
Were there any errors when building GRASS? Try running "make" again.
Note that the 5.7 build system no longer aborts at the first error; it
will compile as much as it can. Even if "make" completes, some modules
may not have been built.
Glynn Clements <glynn.clements at virgin.net>
