[GRASSLIST:3912] Re: building gdal for grass57
Kirk R. Wythers kwythers at umn.edu
Wed Jul 14 14:35:13 EDT 2004
> The r.in.gdal directory is not copied over with make mix any more; the
> version in 5.7 is different and uses GPJ_wkt_to_grass() to convert the
> projection information instead of the old wkt_to_grass() internal to
> GDAL. I changed that a week or two ago and at the same time removed
> the setting of -DUSE_GDAL_H from the configure script.
> (so the problem here was probably that Kirk didn't run make mixclean
Exactly. See my confession in an earlier email about not reading the
INSTALL  file carefully.
At least I'm following the logic of what was going on now. Thanks
Kirk
> to remove the gdalbridge.c and gbgetsymbol.c and the 5.7 build system
> automatically compiles every C file in the directory)
> Markus knew I was doing that but I will start announcing important
> changes like that on the developers mailing list now there is more
> interest :)
> Paul
Kirk R. Wythers	                                    tel: 612.625.2261
Dept. of Forest Resources                fax: 612.625.5212
University of Minnesota     email: kwythers at umn.edu
