[GRASSLIST:3894] Re: building gdal for grass57
Glynn Clements glynn.clements at virgin.net
Tue Jul 13 19:46:27 EDT 2004
Kirk R. Wythers wrote:
> For some reason I have access to gdal through grass53, but not grass57.
> I just cvs up'ed gdal and was getting ready to rebuild it when I
> noticed an option for building with libgrass.
> Does gdal need to be built with:
> --with-grass=ARG  Include GRASS support (ARG=no or libgrass path)
> option?
No. In fact, using that option may result in a GDAL library which
doesn't work with GRASS.
> I just can't remember from the last time I did this, and if that is the
> case, where (in the usr/local) world, does librass get placed?
> find / -name libgrass was coming up empty.
libgrass isn't part of GRASS; it's a separate (and entirely
"unofficial") package. You can't build it from the stock GRASS source
code.
Glynn Clements <glynn.clements at virgin.net>
