[GRASSLIST:3920] Re: worldwide SRTM data now available
Hamish
hamish_nospam at yahoo.com
Thu Jul 15 06:25:27 EDT 2004
An update on the ETOPO2 data, it is actually elevations for both
above and below sea level at 2' (3.7-km-sq) horizontal resolution.
Download: (111mb)
http://www.ngdc.noaa.gov/mgg/global/relief/ETOPO2/
Load into a Lat/Lon location with this command:
r.in.bin -s input=ETOPO2.dos.bin output=etopo2 \
title="worldwide 2' topography (3.7km-sq)" \
bytes=2 rows=5400 cols=10800 n=90N s=90S e=180E w=180W
Recolor with this command (GRASS 5.3.0+):
r.colors etopo2 rul=terrain
(I edited the color map in the $MAPSET/colr/ directory to make the
oceanic fade to black happen at 10000m depth, not 500m depth)
Resulting snapshot is attached.
To make it look good in NVIZ, I had to scale it with:
r.mapcalc "etopo2_scaled=etopo2/(60*1852.0)"
This makes the XYZ into degrees*deg*deg instead of deg*deg*meters;
then you need to redo the colors.
Perhaps a better solution in NVIZ is called for when dealing with
lat/lon projections? Assume meters? see shade.clr.sh fix for this.
Great stuff.
I think this would make a nice GRASSNews newsletter sidebar article, but
I can't find much time right now. I'll try and put something together
over the next day or two, but maybe not.
Hamish
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040715/33e2e05b/etopo2_world_GrassGIS.jpg
