[GRASSLIST:3937] Re: mysql: Cannot open select cursor
    Radim Blazek
    blazek at itc.it
    Fri Jul 16 07:28:48 EDT 2004
The record was created or not (mysql, db.select)?
Radim
On Friday 16 July 2004 11:37, ivan marchesini wrote:
> Dear users...
> I'm working on a debian testing....and grass57
> I have got a problem:
> I connected grass57 with mysql:
> db.connect driver=mysql database=tezio -p
> and after I connected vector attribute to the same db:
> v.database driver=mysql database=tezio -p
> after this, I started v.digit and I created a new table using "settings
> -> table"
> the table was succesfully created!!!
> later, I started to digitize. When I stopped a window appeared saying:
> New record was created.
> Cannot open select cursor:
> 'select * from sentieri where cat = 1'
> on database 'tezio' by driver 'mysql'
> and on the v.digit panel I obtained this:
> dbmi: Protocol error
> WARNING: Cannot open select cursor
> I'm doing something wrong????
> thank you very much for your attention!!!!
> Ivan
