[GRASSLIST:4050] Re: Grass 5.7 vectors
Indictrans Team
indictrans at fastmail.fm
Fri Jul 30 09:39:56 EDT 2004
we had created a map in grass 5.0 version and were
successful in assigning labels to different regions
of the map using the following sequence of
commands::
v.support
d.vect.labels
now we want to implement the same using grass 5.7 version, also we want
to add the labels in hindi which requires the use of UTF-8.now grass 5.7
does support UTF-8 however the above two commands hve been deprecated.We
tried the alternative v.label and d.text however unsuccessfully.Could
anyone kindly help.
Shipra
Kanhaiya
Nandini
Pooja
Indictrans Team
