[GRASSLIST:4052] Re: Grass 5.7 vectors
Radim Blazek blazek at itc.it
Fri Jul 30 11:52:02 EDT 2004
You can use
d.vect display=attr attrcol=xxx
or
v.label + d.paint.labels
Radim
On Friday 30 July 2004 15:39, Indictrans Team wrote:
>                      we had created a map in grass 5.0 version and were
>                      successful in assigning labels to different regions
>                      of the map using the following sequence of
>                      commands::
>                         v.support
>                          d.vect.labels
> now we want to implement the same using grass 5.7 version, also we want
> to add the labels in hindi which requires the use of UTF-8.now grass 5.7
> does support UTF-8 however the above two commands hve been deprecated.We
> tried the alternative v.label and d.text however unsuccessfully.Could
> anyone kindly help.
> Shipra
> Kanhaiya
> Nandini
> Pooja
> Indictrans Team
