[GRASSLIST:3571] NVIZ in 5.7
Gerry James
gjames at bgcengineering.ca
Tue Jun 1 18:25:10 EDT 2004
I am trying to run NVIZ in 5.7 and I keep getting the same error. I have
tried to run it from the command line while loading the elevation.dem data
that comes with the sample data and get the following lines
Loading Data
Update elev null mask
Loading Data
translating colors
Adding panels from /usr/local/grass57-29_05_2004/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
child killed: segmentation violation
while executing
"exec /usr/local/grass57-29_05_2004/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass57-29_05_2004/etc/nviz2.2/scripts/nviz2.2_script
elevation.dem -name NVIZ ..."
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass57-29_05_2004/bin/nviz" line 16)
I have tried copying the nviz2.2_script into a number of different areas
with no luck.
Can anyone help me out.
Cheers
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040601/e606f7d0/attachment.html
