[GRASSLIST:3572] Re: NVIZ in 5.7
    Michael Barton
    michael.barton at asu.edu
    Wed Jun  2 02:25:59 EDT 2004
Gerry,
I believe you've hit a known bug in GRASS 5.7. NVIZ won't start from
the GUI g.parser interface you get when you run it from the command
line, nor will it accept front loaded elevation data (or any other
data). The only way it will run is to start 'quietly' without loading
data up front.
nviz -q
Then load the data once NVIZ has started.
Michael Barton
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Jun 1, 2004, at 10:01 PM, Multiple recipients of list wrote:
> From: "Gerry James" <gjames at bgcengineering.ca>
> Date: June 1, 2004 3:25:10 PM MST
> To: <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:3571] NVIZ in 5.7
> I am trying to run NVIZ in 5.7 and I keep getting the same error.  I
> have tried to run it from the command line while loading the
> elevation.dem data that comes with the sample data and get the
> following lines
> Loading Data
> Update elev null mask
> Loading Data
> translating colors
> Adding panels from /usr/local/grass57-29_05_2004/etc/nviz2.2/scripts
> Nv_(panels)
> toplevel made
> child killed: segmentation violation
>     while executing
> "exec /usr/local/grass57-29_05_2004/etc/nviz2.2/NVWISH2.2 -f
> /usr/local/grass57-29_05_2004/etc/nviz2.2/scripts/nviz2.2_script
> elevation.dem -name NVIZ ..."
>     ("eval" body line 1)
>     invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
> >&@stdout"
>     invoked from within
> "if {$argv == ""} {
> #no arguments
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ
> >&@stdo..."
>     (file "/usr/local/grass57-29_05_2004/bin/nviz" line 16)
> I have tried copying the nviz2.2_script into a number of different
> areas with no luck.
> Can anyone help me out.
> Cheers
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040601/34b35333/attachment.bin
