[GRASSLIST:3575] Re: NVIZ in 5.7
Gerry James
gjames at bgcengineering.ca
Wed Jun 2 10:40:30 EDT 2004
Thanks for the input Michael. I have tried running it quietly (nviz -q) in
both 5.3 and 5.7 and get the same sort of error...Are you aware of any
problems with the NVWISH2.2 executable. I am not sure but it looks like it
is originating from there...Also in some of my reading it appears that there
may be some problem with running it with Tcl/tk 8.4. That is what we are
running for a number of applications...
Cheers
Gerry James, Geomatics Manager
Geomatics and Information Management Group
BGC Engineering Inc.
604 684 5900 ext. 126
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]On
Behalf Of Michael Barton
Sent: Tuesday, June 01, 2004 10:26 PM
To: Multiple recipients of list
Subject: [GRASSLIST:3572] Re: NVIZ in 5.7
Gerry,
I believe you've hit a known bug in GRASS 5.7. NVIZ won't start from the
GUI g.parser interface you get when you run it from the command line, nor
will it accept front loaded elevation data (or any other data). The only way
it will run is to start 'quietly' without loading data up front.
nviz -q
Then load the data once NVIZ has started.
Michael Barton
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Jun 1, 2004, at 10:01 PM, Multiple recipients of list wrote:
Date: June 1, 2004 3:25:10 PM MST
To: <GRASSLIST at baylor.edu>
Subject: [GRASSLIST:3571] NVIZ in 5.7
I am trying to run NVIZ in 5.7 and I keep getting the same error. I
have tried to run it from the command line while loading the elevation.dem
data that comes with the sample data and get the following lines
Loading Data
Update elev null mask
Loading Data
translating colors
Adding panels from /usr/local/grass57-29_05_2004/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
child killed: segmentation violation
while executing
"exec /usr/local/grass57-29_05_2004/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass57-29_05_2004/etc/nviz2.2/scripts/nviz2.2_script
elevation.dem -name NVIZ ..."
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass57-29_05_2004/bin/nviz" line 16)
I have tried copying the nviz2.2_script into a number of different areas
with no luck.
Can anyone help me out.
Cheers
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040602/465e74fb/attachment.html
