[GRASSLIST:3577] Re: NVIZ in 5.7
Michael Barton michael.barton at asu.edu
Wed Jun 2 13:04:35 EDT 2004
If you are running under Cygwin, there is a documented problem. Rich
Greenwood has provided a version of tcltk that works
(www.greenwoodmap.com). If you are running on Mac, you need to install
an x11 version of tcltk and not go with the one that Apple provides.
This can be had via fink or if you use Lorenzo Moretti's binaries. For
other platforms, I don't know. Try setting the path to wish in the
.grassrc57 file in your home directory.
Michael
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jun 2, 2004, at 7:40 AM, Gerry James wrote:
> Thanks for the input Michael.  I have tried running it quietly (nviz
> -q) in both 5.3 and 5.7 and get the same sort of error...Are you aware
> of any problems with the NVWISH2.2 executable. I am not sure but it
> looks like it is originating from there...Also in some of my reading
> it appears that there may be some problem with running it with Tcl/tk
> 8.4.  That is what we are running for a number of applications...
> Cheers
> Gerry James, Geomatics Manager
> Geomatics and Information Management Group
> BGC Engineering Inc.
> 604 684 5900 ext. 126
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]On
> Behalf Of Michael Barton
> Sent: Tuesday, June 01, 2004 10:26 PM
> To: Multiple recipients of list
> Subject: [GRASSLIST:3572] Re: NVIZ in 5.7
> Gerry,
> I believe you've hit a known bug in GRASS 5.7. NVIZ won't start from
> the GUI g.parser interface you get when you run it from the command
> line, nor will it accept front loaded elevation data (or any other
> data). The only way it will run is to start 'quietly' without loading
> data up front.
> nviz -q
> Then load the data once NVIZ has started.
> Michael Barton
> C. Michael Barton, Professor
> PO Box 872402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
> On Jun 1, 2004, at 10:01 PM, Multiple recipients of list wrote:
> From: "Gerry James" <gjames at bgcengineering.ca>
> Date: June 1, 2004 3:25:10 PM MST
> To: <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:3571] NVIZ in 5.7
> I am trying to run NVIZ in 5.7 and I keep getting the same error.  I
> have tried to run it from the command line while loading the
> elevation.dem data that comes with the sample data and get the
> following lines
> Loading Data
> Update elev null mask
> Loading Data
> translating colors
> Adding panels from /usr/local/grass57-29_05_2004/etc/nviz2.2/scripts
> Nv_(panels)
> toplevel made
> child killed: segmentation violation
>     while executing
> "exec /usr/local/grass57-29_05_2004/etc/nviz2.2/NVWISH2.2 -f
> /usr/local/grass57-29_05_2004/etc/nviz2.2/scripts/nviz2.2_script
> elevation.dem -name NVIZ ..."
>     ("eval" body line 1)
>     invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
> >&@stdout"
>     invoked from within
> "if {$argv == ""} {
> #no arguments
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ
> >&@stdo..."
>     (file "/usr/local/grass57-29_05_2004/bin/nviz" line 16)
> I have tried copying the nviz2.2_script into a number of different
> areas with no luck.
> Can anyone help me out.
> Cheers
