[GRASSLIST:3634] Re: error cannot create table on v.in.ogr command
Radim Blazek
blazek at itc.it
Wed Jun 9 01:35:30 EDT 2004
schema option in v.database means the name of a schema
in Postgres database. Schemas are supported only in latest
versions of Postgres. Most probably you don't want to use
schemas at all, in that case, unset schema:
v.database driver=pg database=testdb schema=
If you realy want to use schemas, the schema 'postgres'
must exist in your database 'testdb'.
Radim
On Tuesday 08 June 2004 20:26, Didit Ahendra wrote:
> hi listers..,
> Now I'm work with grass 5.7 and data from
> ArcView(shape file).
> A few minute ago, I want to import my data (.shp) in
> grass with the attribute in database.
> I use postgresql for database.But there is error while
> I execute v.in.ogr command.
> command that I execute and the error:
> v.database driver=pg database=testdb schema=postgres
> v.in.ogr dsn=/mnt/win/dewa/shp_file/administrasi/
> output=administrasi layer=administrasi min_area=0.0001
> type=boundary snap=0.001 -c
> PROJ_INFO file not found for location latihan
> PROJ_UNITS file not found for location latihan
> Projection of input dataset and current location
> appear to match.
> Proceeding with import...
> Layer: administrasi
> DBMI-Postgres driver error:
> Cannot execute:
> create table postgres.administrasi (cat integer, ID
> integer, KECAMATAN varchar ( 20 ), LUAS_AREA double
> precision, BANGKITAN integer, TARIKAN integer)
> ERROR: Namespace "postgres" does not exist
> ERROR: Cannot create table: create table
> integer, ID integer, KECAMATAN varchar ( 20 ),
> LUAS_AREA double precision,
> can you help me to solve my problem,please?
> thank's for your help before.
> regard,
> Didit
> __________________________________
> Do you Yahoo!?
> Friends. Fun. Try the all-new Yahoo! Messenger.
> http://messenger.yahoo.com/
