[GRASSLIST:3698] Re: [GRASS5] GRASS 5.7.0 beta5 - Report
Radim Blazek blazek at itc.it
Thu Jun 17 12:10:18 EDT 2004
On Thursday 17 June 2004 12:21, Lorenzo Moretti wrote:
> Hi Radim,
> compilation worked fine
> Three questions:
> v.label. It's impossible to create labels with v.label if I use
> v.external for linking a shape files. If I import a shape file with
> v.in.ogr I can create a label with v.label. Is it a feature or a bug?
http://grass.itc.it/pipermail/grass-commit/2004-June/011972.html
> NVIZ only works with DEM or raster files. It'impossible to add a
> vector file. Example: in terminal I see:
> BROWSER: .fbrowse TYPE: vect MODE: 1
> Vector file perimeter at PERMANENT loaded.
> Total vect memory = 502 Kbytes
> but the vector is not displayed on the screen over the DEM. NVIZ in
> Grass 53 works.
It should work, are you sure the vector is not 3D with z coors outside
the view?
Radim
