[GRASSLIST:3727] Re: gnu software for digitizing
juan pablo perez
valdentro at hotmail.com
Mon Jun 21 04:29:18 EDT 2004
Dear michael...
I don't understand how to do that you say: "crop it and save as dxf while in
GIMP".
I'm working with the GIMP 1.2.3 and it can't save in dxf format...
Juan Pablo
>From: michaelsalisbury <michaelsalisbury at comcast.net>
>To: "juan pablo perez" <valdentro at hotmail.com>
>Subject: Re: [GRASSLIST:3709] gnu software for digitizing
>Date: Fri, 18 Jun 2004 06:37:33 -0700
>I've used Qcad and Gimp for Digitizing. Load whatever Tiff, Giff, jpeg etc
>into gimp crop it and save as dxf while in GIMP then import it into Qcad to
>Digitize. Qcad has layering capabilities. It's awkward, but qcad does use
>layers. Qcad has the disadvantage of being 2D, I don't know if that would
>hinder you. There are other free/opensource cad's such as Varkon, and
>BRL-cad that you could obtain and possibly use. Varkon is easy enough to
>download and build but is more difficult to learn and BRL-cad is truly 3D
>but you have to send the US Army some signatures and then they'll email you
>the source tar.
>As far as Qcad, when you open Qcad look on the left hand of the w"indow and
>there is a menu "Layer List", under that there is six buttons, an eye
>highlighted, eye unhighlighted, a plus, a minus, colors, and a trash bin.
>the two eye buttons are to turn on/off a particular layer, the plus and
>negative are to add/delete a layer, and the color button if for layer
>properties. Maybe you aren't working with latest qcad. The maintainers
>of Qcad do not offter the binaries. You have to build the latest Qcad from
>source . Or if you use debian it's in the testing or stable lists.
>On Friday, June 18, 2004, at 04:50 AM, juan pablo perez wrote:
>>Hi
>>I'm working with my pupils with GRASS (developping several DEMs) and they
>>have problems because v.digit is not as friendly as is MapInfo (as a first
>>module we worked with it)
>>Is possible to work whit another gnu-program that supports raster images
>>and layers to digitize contours and export them (e.g. as *.dxf) into
>>GRASS?. I tried with The GIMP, but it don't exports in vector format; also
>>tried with QCad, but it has not support for raster layers,...
>>Can anybody help us?...
>>_________________________________________________________________
>>Reserva desde ahora tus vacaciones en MSN Viajes. Más cómodo, más barato y
>>más opciones. http://www.msn.es/Viajes/
Dale rienda suelta a tu tiempo libre. Encuentra mil ideas para exprimir tu
ocio con MSN Entretenimiento. http://entretenimiento.msn.es/
